Robot swept volume in ABB RObot studio
              I want to create robot interference zone (Swept volume) according to the path. Kindly help me in this case. For an example how it will be viewed robot envelope similarly its a requirement .
It will be great if anyone could help me in this case... :-)
Thanks and regards,
Revathi D
  • What do you mean by 'swept volume'?
  • When we play the simulation I want to save the trajectory of the robot as 3D data, Its for to ensure the clearance between the robots.
  • That is a quite difficult problem to solve. Is it not enough to use collision detection?
    Johannes Weiman
    RobotStudio Team, ABB Robotics
  • Nope, I want this as a separate 3D data to save it. Do you thing is it possible to do take the interference data?
  • Adnan
    Adnan admin
    You have to go to RobotApps in RS and downlaod Smart Component called "PartTrace".
    /Adnan
