ArcWelding for begginers
Hello, I've got a problem with arc welding power pac, I don't know how
to start with that, I need to create station with 2 robots, where one
holds welded part, while the another welds it. I don't know what, but
I'm doing something wrong. When I use one robot it works. I don't really
know how to create weld properly, but robot moves. When I use station
with 2 robots, it doesn't work.
Have anyone seen some tutorials on the internet?
I would be really happy if anyone would help me somehow.
1
Little update, I figured out how to create welds, but I have problem with robots sync, I want to create instruction for one robot wich is executed after the other robot finishes it's task.
need to create someting like this, I think about creating DO and DI signals to communicate between robots, like robot "says" reorient welded object. But I think it isn't correct way. I also thoud about syncronising it using time, but that seems incorrect as well. How to do that?
1 -
How do you create weld with AWPP ?
Does anyone have tutorial/online training for AWPP ? The operating manual available is not easy to follow
Interesting that nobody could or whants to answer this question, where is abb support?0
Do you have multimove installed? If you have multimove, you could use syncID's to control both Robots. One with no welding the other with the welding procedure.0
I have just this month returned at the using of RS.
Can any one make a smalle tutorial on how to create a weld?
I really feel like a noob asking, since i have used the first RS versions for S4 and when RS 5 came out in 2008.
But been away for 6 years
Kent Zibrandtsen
Dept manager robot welding
Kez@hardi-international.com0 -
Are these questions still valid?
The very first question is a fairly difficult task to start with no additional training.
I can post tutorial or a sections of it if people still need help.1
- 367 IRC5
- 858 RAPID Programming
