S4C+ Profibus DP slave setup
jeffdu
Hello
What do you do to set up a DSQC 352? I want to control the robot with a PLC (Siemens S7-1200 with Profibus DP master module). What exactly do I need to do? Can't find it on manual or google. I've connected them with the cable.
Thank you
Thank you
Hey!
I think this is all you have to do in the eio.cfg file.
You also need to set the device net address correct and also set the correct input/output size in the plc.
You can read about that in thi link:
http://host.bglot.com/ABB/ABB_3HAC020676-001_revB_en.pdf
EIO:CFG_1.0:3:1::#EIO_UNIT:-Name "Profibus" -Type "d352" -Bus "BASE" -Digin 129 -Digout 128\-PollRate 100 -Param "Profibus_VAL"#Profibus_VAL = EIO_PARAM_VALUE:-Name "MasterInputSize" -Value "8"-Name "MasterOutputSize" -Value "8"-Name "StationAddress" -Value "4"1 -
Thanks Joar! I got it working. Now I have 128 extra I/O to the PLC:)
Hello Jeffdu,
I have the same configuration:
- ABB S4C+ controller
- ABB DSQC352 Profinet
- Siemens C1214C DC/DC/DC
- Siemens CM 1243-5 Profibus card
The ABB is configured as adress 3, and the PLC is configured as adress 2
But the PLC keeps reporting to have no connection with the ABB controller.
Could you show how you configured the Siemens PLC for the profibus connection?
rcool0 -
hello
does it require to set DSQC352 same address in both place ?
In EIO.CFG and jumper pins(X5)?0
- 5.4K RobotStudio
- 383 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 405 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 279 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 734 RAPID Programming
- 15 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
