Object Frame , Wobj
Hi, all
I have values X,Y and angle from camera. I have values via position  on PCB.
I want to move robot to via position on PCB. I know when PCB rotate but i don't know how to used robot follow PCB. I think i will use object frame but i don't know command code.
How to use command offset object frame?
PS. If you have better solution. Please tell me.
Sorry if you  understand.
My english is not well.
Thanks you.
