Problem with coordinate system of the track and base of robot
Symi
Symi
edited February 2020 in RobotStudio
Hi there,
short overview:
-robot is mounted on external linear axis
- linear axis of the track is similar to robot y axis
So if i move the robot manually coordinates are correct as you can see in upper left corner. But if i look on my virtual flex pendant, the coordiantes are totally different. How do I fix this?
  • Symi
    Symi
    Maybe some further informations:
    track is from GÜDEL, but motor is from ABB -> MU300
    I tried to rotate baseframe of the robot and from track (separated from each other), but nothing had changed.
    I used External Axis Wizard to create the track.
  • Tap the position format button (below the co-ordinate readout) -> position shown in-> from workobject to world on the Flex Pendant
  • Symi
    Symi
    It doesn't matter which position format i use. the incorrect calculation remains. In the meantime, ive send my problem with a pack&go file to the support. I hope that they can help me :).
    wObj = (0,0,0) = Base
    Post edited by Symi on
