Problem with coordinate system of the track and base of robot
Symi
Hi there,
short overview:
-robot is mounted on external linear axis
- linear axis of the track is similar to robot y axis
So if i move the robot manually coordinates are correct as you can see in upper left corner. But if i look on my virtual flex pendant, the coordiantes are totally different. How do I fix this?
Maybe some further informations:track is from GÜDEL, but motor is from ABB -> MU300I tried to rotate baseframe of the robot and from track (separated from each other), but nothing had changed.I used External Axis Wizard to create the track.0
Tap the position format button (below the co-ordinate readout) -> position shown in-> from workobject to world on the Flex Pendant
It doesn't matter which position format i use. the incorrect calculation remains. In the meantime, ive send my problem with a pack&go file to the support. I hope that they can help me
.wObj = (0,0,0) = BasePost edited by Symi on0
