Perform Jogging by WebSockets
tlt
I try to do http://localhost/rw/motionsystem?action=jog and get following message:
Could you clarify what does Change count mismatch mean?
<span class="code">-1073436652</span>
<span class="msg">rws_resource_motionsystem.cpp[405] Change count mismatch code:-1073436652 icode:-1073436652</span>
Robot error list:
Robot error list:
<li class="err-desc-li" title="-1073436652">
<span class="name">SYS_CTRL_E_HPJ_CHANGE_COUNT_MISMATCH</span>
<span class="severity">Error</span>
<span class="description">Change count mismatch.</span>
Check out this forum post:
https://forums.robotstudio.com/discussion/12180/how-to-get-started-with-robot-web-services-and-jog-a-robot-via-rest-api-requests#latest
https://developercenter.robotstudio.com/api/rwsApi/ms_motionsystem_get_page.html
"change_count = counter to keep count for every change in the motion system(domain)"
We need to find the correct change count which we need to send to the controller with the jog request.
So first we GET this resource: http://localhost/rw/motionsystem?resource=change-count
This will return a <span class="change-count">0</span> which is the value we use in the jog request.
"6
