Collision Avoidance Error
Hello everyone,
I have a station with an IRB 5500, a paint robot, and an elevated rail for it and I'm trying to configure de Collision Avoidance option but it seems that it doesn't work with paint robots. I have proved with other paint robots without the track and it hasn't worked, so I have proved with other non-paint robots and it has worked correctly.
Does anyone know why this option doen'st work with paint robots?
The errors than appears are the following:
Thanks a lot!
Thanks a lot!
Hello,Unfortunately, paint robots are not supported by the collision avoidance.
—Nils OlofssonPC Software Support Engineer0 -
Having the same problem with IRB 14000 (YuMi), does it mean that it is not supported for collision avoidance function as well?0 -
This is a bug in RobotStudio; the collision avoidance commands should not have been enabled for paint robots.
It should work with Yumi though.Johannes Weiman
RobotStudio Team, ABB Robotics0
- 858 RAPID Programming
