About RobotStudio AR Viewer
Ekhi
mod
‘RobotStudio® AR Viewer’ is an augmented reality (AR) application designed to work with iOS and Android mobile devices. The application visualises in 3D the industrial robots simulation created in the ‘RobotStudio’ desktop application. With ‘RobotStudio® AR Viewer’, users get an exact copy of the ABB robots in 3D, with the robot’s movements accurately reflected.
The augmented reality features enable precise positioning of a robot on the shop floor, which contributes to better understanding about how it will fit in the space. Additionally, it is possible to resize the robot to the desired size, adjust station rotation to see it from each angle, while its timeline feature makes it possible to check the cycle time and go quickly to a certain point in time in the animation.
The application requires only 3 simple steps to get started: exporting the simulation from the desktop application, placing the exported simulation file on the cloud drive (e.g. OneDrive) and importing the simulation into the mobile application.
A new release is available !
ABB RobotStudio® Augmented Reality video https://www.youtube.com/watch?v=an9XiXjHaw8
What's new?
You can now find the ABB's portfolio of robots and robotics solutions : more than 50 robot arm models and more than 20 robotics solutions in different industries and applications.
Select your robot model or application with filtering options.
Interact with the model with user friendly gestures.
Download the free app from Apple, Google and Huawei store and enjoy the experience !
2
How does one obtain the RobotStudio AR Viewer app for my android device?0
Link to the demo video https://abbtv.inside.abb.com/2020/02/18/robotstudio-ar-viewer-visualising-an-exact-copy-of-abb-robots-in-3d-using-augmented-reality-is-innovation-and-digital-scouting/ goes to an Internal ABB page and states "Unauthorized"
Hello j_proulxFB, the app is now available in the Apple AppStore here
https://apps.apple.com/us/app/id1514364084
And in the Google PlayStore here :
https://play.google.com/store/apps/details?id=com.abb.hayes
The link of the video is updated : try this one https://search.abb.com/library/Download.aspx?DocumentID=9AKK107680A8917&LanguageCode=en&DocumentPartId=&Action=Launch
Post edited by Ekhi on0 -
Hello I have a Xiaomi A2, with Android 10, but I can't download the APP, because google says my phone is not compatible.What happens?.Jorge Turiel0
Hello Jorge,
app is using Google ARCore and Xiaomi A2 is not supported by Google ARCore.
Here is a list of supported devices: https://developers.google.com/ar/discover/supported-devices
Best regards.0 -
Its really helpful information0
It's a app with nice potential to become an engineering tool, but for now, it is unfortunetlly only an marketing gadget in my opinion. First problem is that after importing an simulation offsetting it position can be done only by moving the scene over the screen. Please make normal window where valuse in X, Y and Z axis can by typed in. Same with resizing - make an window to type the value. Currently the scene is being resized basing on 0,0,0 point and for unknown reason while resizing it offset the objects in Z axis as well - and while the Z level is "automaticaly" detected, and cannot be corrected the scene starts to fly over the floor level... What is good, the the engine of application works very good, while moving around it recognize the position and orientation of the smartphone very well, so it mentioned above problems could be solved then it could became really usefull tool. Unfortunetly for now, matching the objects with the real elements of the enviroment is simply impossible.0
Hello @michal_piotrowski
Thank you for your feedback, for the majority of the users touchscreen gestures are the most intuitive way to offset / move / pan / tilt a model.
Today to rotate the model you have a slider, we also can consider the possibility to add a slider for the offseting.
Anyway, offset the Z level is planned for futur.
helpful information rangextd wifi extender-1
- 10.4K All Categories
- 5.3K RobotStudio
- 351 UpFeed
- 15 Tutorials
- 9 RobotApps
- 282 PowerPacs
- 404 RobotStudio S4
- 239 ScreenMaker
- 2.6K Robot Controller
- 251 IRC5
- 36 OmniCore
- 3 RobotStudio AR Viewer
- 701 RAPID Programming
- 14 Wizard Easy Programming
- 3 Job listings
