Sematic Errors in RAPID
Armbross
Hello I have problems with Rapid programming.
Path programming Bottom1 where a gripper moves to pick up an object. When teach targets and checking its reachability it was ok. But when PulseDO and WaitTime was added, was presented with 1 sematic error. Have tried using Check Program option in Rapid but didn't see any error in my programming
https://gofile.io/d/XMqQ7l
If you change the signal type to DO instead of DI in Configuration it should work.1
thnk you its works now0
