How to use tool I/O (XS12)
Hey guys,
have a question about our abb yumi irb14000. I want to send a digital output signal to the tool flange off the right hand. I thought this would be possible via a cross connection bettween the xs12 connector (tool i/o) and the xs7 connector(digital outputs). I tryed it out and tested it with a voltage meter, but there wasn't a signal for all the time. Is there an software option which disables the ethernet on the toolflanges and enables the digital i/o on the tool flange?
I hope you can help me.
Sorry for my bad englisch.
Thanks in advance.
Thanks in advance.
option which disables the ethernet on the toolflanges0
Hello xerim,
https://library.e.abb.com/public/5f8bca51d2b541709ea5d4ef165e46ab/3HAC052982 PS IRB 14000-en.pdf?x-sign=t3HHvF5H6qsxBC83e7PHCFA18NswGcGF9Y7f99vUKTWzvvzonYm8rlB5iHb9V6FP
I saw page 74 of this productspecification, which means that the xs12 is for tool-i/o-signals. My problem is, that i tried this out and it doesn't work. I never get a signal out of the toolflange. You know what i mean?
Can you tell me the procedure to use the xs12-slot for tool i/o?
Best regards
Florian0 -
We could solve it. We opened the Case of the yumi and connected the ethernetcable of the arms with the cable to the xs12slot. Now we could use it as digital i/o's. If we want to use it as ethernet again, then we have to turn this back and connect the cables from the arms again with the ethernet switch in the yumi. You know what i mean?
With best regards
Florian.0 -
Please see the attached document file, it might help you.
Best Regards,
ABB YuMi Guide0
- 348 IRC5
- 844 RAPID Programming
- 21 AppStudio
