Error at creating station
WallE
Hello everybody,
i worked with robot studio version 6.8 until yesterday (full license)
After installation RS 2019_4, i can no longer create stations with version 6.8.
If the control is to be generated from backup I have the following error.
RobotStudio .NET exception: C0040701 : One or more files in the release directory is corrupt and cannot be used when launching a VC.
IRobVC.Launch()
Base exception: RobApiException
IRobVC.Launch()
bei System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
bei System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
bei RobotStudio.Services.Systems.SystemBuilder.SystemBuilderGandalf.<CreateSystemFromBackupAsync>d__15.MoveNext()
--- Ende der Stapelüberwachung vom vorhergehenden Ort, an dem die Ausnahme ausgelöst wurde ---
bei RobotStudio.UI.Controller.DefineSystemCtrl.<CreateSystemFromBackupAsync>d__9.MoveNext()
bei RobotStudio.UI.Controller.DefineSystemCtrl.<CreateSystemAsync>d__8.MoveNext()
bei ABBInternal.Controller.SystemFromLayout.CreateSystemCtrl.<ApplyAsync>d__19.MoveNext()
Does anyone know where this is coming from?
thank you in advance
Bodo
Hi Bodo,
For assistance with this issue I recommend that you contact your local ABB Support team who can help you. You can find the contact information at https://new.abb.com/contact-centers.
Best Regards,
Liam0 -
I'm currently having this issue and it seems to be partly due to Admin privileges. Robotware installs to the Appdata directory of the user account. For non-admin accounts at my workplace it seems to not install correctly.0
- 365 IRC5
- 84 OmniCore
