Global routine name main ambiguous.
sud213
hi all,
i save a very simple code to run on IRB2400/16 Kg with S4C controller. It has one module and ONLY one MAIN Proc but it keep showing that "Global routine name main ambiguous." on the teach pendent .
What should I do?
Should I synchronize it to virtual controller or station first? or it is not related. the simulation works perfectly.
Thanks for your answers in advanced!
1
Could you post how does your main module look like?0
Have you called you module "Main" also?0
The same problem appeared to me on [YuMi IRB 14000] after using the code from this repo: [link](https://github.com/ethz-asl/yumi/tree/addition/Demo/yumi_support/rapid) according to this tutorial [link](https://github.com/ethz-asl/yumi/wiki/Setting-Up-YuMi-in-RobotStudio#transfer-ros-modules-to-controller) RobotWare 6.10, SmartGripper Firmware 3.56
The ambiguous error means there are two items with the same name.1
- 365 IRC5
- 84 OmniCore
