Safemove Function Mappings
Hello, I am about to prepare offline a profisafe communication between siemens plc and irb. Can someone explain to me how to understand "Function mapping" and how to work with it?
Additionally I couldn't find any helpful information how to understand "CommissioningModeActive" and when it is used exactly.
  • How did this work out for you?I am using some Profisafe signals between controller and external Profinet host. Need to send e-stop status and receive external e-stop and machine gates status.  So far I have connected the function "LocalEmergencyStopStatus" to the Profisafe output via "Function mappings" It seems there are only two input functions here, "ExtComShutdownAck" and "SafetyEnable".
  • Hello, I am about to prepare offline a profisafe communication between siemens plc and irb. Can someone explain to me how to understand "Function mapping" and how to work with it?
    Hi Marek,
    Did you solve your problem ?
    I have the same, I can not add my confiugured SDI to the singals in Safe IO confidurator
  • I would of course suggest you go on a SafeMove course to learn the correct way to use it. To configure the IO signals in Profisafe you must do it in the I/O Engineering Tool which you will find under the Controller tab in RobotStudio and pick from the ribbon Configuration and then I/O Engineering tool.
