I/O Configurator 6 not working with custom user
Tompanhuhu
Hi.
We have removed the Default User permissions in a robotcell and created a custom user with the proper permissions.
When i'm logged in with a custom user and try to edit I/O signals with I/O Configurator 6 i get the error showed in the image.
However i'm able to change I/O signals with the default configuration in the "Controller" tab on robotstudio.
☑️2024 - RobotStudio® User Group
Did you login on the pendant or in RobotStudio?
If only on the pendant use the Authenticate button on the controller tab to login.0 -
Ofcourse I was logged in with robotstudio.Systemintegrator - Web / C# / Rapid / Robotstudio
bumpSystemintegrator - Web / C# / Rapid / Robotstudio
Hello Tompan,
If you find this to be a pressing issue, please contact your local ABB and ask for their assistance.
If this is a bug it will get escalated internally.
Thanks!
- 365 IRC5
- 84 OmniCore
