acceleration limit for IRBT2005
Good evening,
    Can I get some help regarding limiting acceleration for IRBT2005 track ? I know for the robot it is AccSet, but it's not working for track,
Thank you
  • lemster68
    lemster68 ✭✭✭
    In the MOC configuration for the unit, you could try wc_acc.
    Lee Justice
  • Im not having any wc_acc param.As you can see in the capture below
    But I think that maybe the param. between rectangle can make a change ?
  • lemster68
    lemster68 ✭✭✭
    I cannot read the text, it is too small for me.  I suggest that you read the system parameter manual, under the motion topic, Acceleration data type.
    Lee Justice
