Error during creating a new virtual controller "RobotStudio .NET exception..." RWS 6.12.3010
Kappa95
Dear community,
I am trying to setup a virtual controller on RobotStudio 2022.3.2 of a robot with a positioner irbp 250-a. I am using the backup of the controller and following the question (https://forums.robotstudio.com/discussion/11852/3hea-01600-800215-00-missing) I have copied the configuration folder into. But When I try to create a new virtual controller, the following error happens:
RobotStudio .NET exception: Product installation failed for new system Given productDistribution does not have any rpk files<br>============================================<br>Base exception: ProductInstallationFailedException<br>Product installation failed for new system Given productDistribution does not have any rpk files<br> at ABB.Robotics.RIM.RobInstallManager.CreateVirtualController2(ControllerSystem2 cSys, String co<br>ntrollerLocation, String productsInstallationParentPath)<br> at RobotStudio.Services.Systems.SystemBuilder.SystemBuilderRW6.<>c__DisplayClass1_0.<CreateVirtualController>b__0()<br> at System.Threading.Tasks.Task.Execute()<br>--- End of stack trace from previous location where exception was thrown ---<br> at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()<br> at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)<br> at RobotStudio.Services.Systems.SystemBuilder.SystemBuilderRpkBase.<CreateSystemFromBackupAsync>d__12.MoveNext()<br>--- End of stack trace from previous location where exception was thrown ---<br> at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()<br> at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)<br> at RobotStudio.UI.Controller.DefineSystemCtrl.<CreateSystemFromBackupAsync>d__11.MoveNext()<br>--- End of stack trace from previous location where exception was thrown ---<br> at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()<br> at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)<br> at RobotStudio.UI.Controller.DefineSystemCtrl.<CreateSystemAsync>d__10.MoveNext()<br>--- End of stack trace from previous location where exception was thrown ---<br> at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()<br> at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)<br> at ABBInternal.Controller.SystemFromLayout.CreateSystemCtrl.<ApplyAsync>d__19.MoveNext()
Configurations.
How can I solve?
I have solved using the installation manager and installing each rpk from the RPK folder
Hello,Kappa95 said:I have solved using the installation manager and installing each rpk from the RPK folder
How exactly did you do this?0
