What is the definition of cfx in YuMi
I am working with the YuMi manipulator but It is not obvious when the cfx parameters chage in the robot studio. please give me the information
Hello,YuMi is a 7 axis serial link robot.Looking in RAPID Instruction, Functions and Data types (IRC5) help file at Data types - confdata:7-axis serial link robotsAll four configuration parameters are used. cf1, cf4, cf6 for joints 1, 4, and 6 respectively. cfx is used to select one of 8 possible robot configurations similar to how it works for other robots.cfxAxis 2 angleWrist center relative to lower armAxis 5 angle0PositiveIn front ofPositive1PositiveIn front ofNegative2PositiveBehindPositive3PositiveBehindNegative4NegativeIn front ofPositive5NegativeIn front ofNegative6NegativeBehindPositive7NegativeBehindNegative
Thank you for your response, Actually now I do not understand what does it mean wrist center relative to the lower arm. what is the exact definition of lower arm, and the wrist center point in YuMi.0
Hello,In RS, you can teach Target. Then in right click on it, you have a Configurations menu.You have a list of possible configurations for teached position with a joint values for each.It seems that you have to represent arm like if axis 1 is on floor axis X oriented on top.So "In Front Of" is that TCP is upper than axis 2 line, and "Behind" is that TCP is lower.☑️2024 - RobotStudio® User Group0
Thank you for your kind response.
And do you know what is the definition of lower arm in YuMi. I have tried to understand it but it was not possible for me.0 -
I think it is axis 2, the nearest (lower) to axis 1...
