Calibration-Related Issue with IRB 4600 Robot and IRC5 Controller: Linear Movement Error
This probably happens because two axes (I guess 4 and 6) are parallel or coincident. Try to manually jog all axes to a few degrees different from 0 first, before jogging linearly. Do you still get this error after that?0
Hi,nicolahinssen said:This probably happens because two axes (I guess 4 and 6) are parallel or coincident. Try to manually jog all axes to a few degrees different from 0 first, before jogging linearly. Do you still get this error after that?
Thanks for answering me. I moved the robot but the problem is the same.
Post edited by DiegoHernandez on0 -
Four and six are in line or too near to it when axis 5 is near zero. Move axis five away from zero and try again.Lee Justice1
Thanks the problem was solved.lemster68 said:Four and six are in line or too near to it when axis 5 is near zero. Move axis five away from zero and try again.0
