Images in forum posts
Newman
Has something changed on this forum regarding attaching images in forum posts?
David
Swedish freelance ABB robot programmer
David
What do you mean?
I can see that when I click on the image button, it only pops up a box which says, "image url". I cannot seem to browse or insert attachment.Lee Justice0
I see.
It should still be possible to upload an image to imgur.com (or equivalent) and link it to the post here.
But as I remember you could paste images directly into your post before?
And instead of just url link you could browse an image from your local harddrive.
/David-----------------
David
I would also like to be able to select images for forum posts directly from my hard drive
/Daniel0 -
It is true that this was possible before.
A decision was made to disable that feature so that it would be impossible to share files, and potentially harmful files, on this platform.
- 367 IRC5
- 858 RAPID Programming
