[Request] RAPID Synchronization
DenisFR
DenisFR ✭✭✭
Can you add ability to synchronize directly robtarget and jointtarget (PERS or CONST), even if they are not in paths?
  • Hello Denis,
    Thanks for your suggestion.
    I'll bring this to R&R's attention.
    Thanks!
    Maxim Riabichev
    PC Software Support Engineer
  • Newman
    Newman
    edited September 2023
    DenisFR said:
    Great idea. Select/multiselect and then right click to sync.
    Post edited by Newman on
    David
    Swedish freelance ABB robot programmer
  • Hello Denis,
    Unfortunately, R&D decided that this functionality is not something they will spend time on implementing.
    Maxim Riabichev
  • DenisFR
    DenisFR ✭✭✭
    If code was open, I can take a look at it. :p
  • Tompanhuhu
    Tompanhuhu ✭✭✭
    Maybe can be done with addin? :)
    If I helped, please press Vote Up  :smile:
  • DenisFR
    DenisFR ✭✭✭
    @Tompanhuhu good point. ;)
  • Tompanhuhu
    Tompanhuhu ✭✭✭
    I had some spare time and made a addin that does this.
    Target's get synched to the module selected in Settings -> Synchronization -> Targets/Jointtargets
    But it's not 100% tested and 2 known bugs are:
    * Sometimes when selecting multiple targets only last target gets synchronized.
    I have had a few station crashes where a minute after last sync I get these errors:
    I have not found out why this happens and don't know when i'll have time to debug it.
    But I'll share the source code if anyone want's to look at it :)
    Sourcecode https://github.com/JETomi/TwRobotstudioSyncTarget
    Packaged addin : https://github.com/JETomi/TwRobotstudioSyncTarget/releases/tag/addin
