[Request] RAPID Synchronization
Hello Denis,
Thanks for your suggestion.
I'll bring this to R&R's attention.
Thanks!
DenisFR said:Hello,Can you add ability to synchronize directly robtarget and jointtarget (PERS or CONST), even if they are not in paths?
Post edited by Newman on-----------------
David
Hello Denis,
Unfortunately, R&D decided that this functionality is not something they will spend time on implementing.—Maxim RiabichevPC Software Support Engineer0 -
If code was open, I can take a look at it.1
DenisFR said:If code was open, I can take a look at it.Systemintegrator - Web / C# / Rapid / Robotstudio
If I helped, please press Vote Up0 -
@Tompanhuhu good point.
I had some spare time and made a addin that does this.
Target's get synched to the module selected in Settings -> Synchronization -> Targets/Jointtargets
But it's not 100% tested and 2 known bugs are:
* Sometimes when selecting multiple targets only last target gets synchronized.
I have had a few station crashes where a minute after last sync I get these errors:
I have not found out why this happens and don't know when i'll have time to debug it.
But I'll share the source code if anyone want's to look at it !
Sourcecode https://github.com/JETomi/TwRobotstudioSyncTarget
Packaged addin : https://github.com/JETomi/TwRobotstudioSyncTarget/releases/tag/addin
- 5.4K RobotStudio
- 381 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 247 ScreenMaker
- 2.7K Robot Controller
- 280 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 737 RAPID Programming
- 15 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
