[Request] RAPID Synchronization
Hello Denis,
Thanks for your suggestion.
I'll bring this to R&R's attention.
Thanks!
DenisFR said:Hello,Can you add ability to synchronize directly robtarget and jointtarget (PERS or CONST), even if they are not in paths?
Post edited by Newman on-----------------
David
Hello Denis,
Unfortunately, R&D decided that this functionality is not something they will spend time on implementing.—Maxim RiabichevPC Software Support Engineer0 -
If code was open, I can take a look at it.☑️2024 - RobotStudio® User Group1
DenisFR said:If code was open, I can take a look at it.Systemintegrator - Web / C# / Rapid / Robotstudio
I had some spare time and made a addin that does this.
Target's get synched to the module selected in Settings -> Synchronization -> Targets/Jointtargets
But it's not 100% tested and 2 known bugs are:
* Sometimes when selecting multiple targets only last target gets synchronized.
I have had a few station crashes where a minute after last sync I get these errors:
I have not found out why this happens and don't know when i'll have time to debug it.
But I'll share the source code if anyone want's to look at it!
Sourcecode https://github.com/JETomi/TwRobotstudioSyncTarget
Packaged addin : https://github.com/JETomi/TwRobotstudioSyncTarget/releases/tag/addin
- 359 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 30 AppStudio
