RobotStudio 2021.1.2 Crashing
JWempe
The most recent version of RobotStudio has been crashing when I try to take a real controller offline. Installation Manager 6 also crashes upon opening while IM7 works fine.
Does anyone have similar issues and solutions?
Where can I find legacy versions of software (i.e. Robotstudio 2020)? I have been unable to find it on the ABB RobotStudio downloads page.
@Maxim Riabichev do you have any comments on this?0
Hello there,
In order to troubleshoot this issue, please contact your local ABB and provide a RobotStudio Report via the Support Tool.
To my knowledge, the older versions of RobotStudio are not available for download any longer.—Maxim RiabichevPC Software Support Engineer0 -
Maxim,It turns out the culprit for the issues was some newly implemented endpoint protection software. I have RobotStudio back up and running.0
Glad to hear that you found a solution!—Maxim RiabichevPC Software Support Engineer0
I am having same issue while creating a new system. Can you please share what software was the issue. i have tried 7 laptops, version 6.07, 2021 and 20230
- 5.4K RobotStudio
- 384 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 405 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 279 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 736 RAPID Programming
- 15 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
