Sematic error with no error?
SBENO
Does someone know what the problem could be with this? (See screenshot in link)
https://imgur.com/pnbbVTH
So it says that I'm having an error but the code works fine on another controller, thanks for the help.
Hello,Where your cameraGapresult type is defined?Maybe an unloaded module...0
No it is there, did a copy paste so all looks the same.
But for some reason i get this error.0 -
Looks like this at the top, don't mind the "X". I added that as a test.
https://imgur.com/YROkYez
And this is the message on the pendant.
https://imgur.com/UBnlNCf
What is your RobotWare version?
And for another controller?
So, maybe they fix it in RobotWare>6.10.Can you update your robot controller?0
DenisFR said:So, maybe they fix it in RobotWare>6.10.Can you update your robot controller?
But it seems to be a problem to update the robotware.
Should it be possible to take a backup from the online controller and create a virtual where I update it?a. Start RS, open controller, and create controller backupb. Close RSc. Start RS (don't open the station yet))d. Modify system using system builder (select wanted RW version)e Open virtual station and create with backup, but change to robotware 6.15f. I-start controller (to make the modification active)g. Restore backup from step 1Post edited by SBENO on0 -
RECORD are value type (as Offs return robtarget).
- 5.4K RobotStudio
- 382 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 247 ScreenMaker
- 2.7K Robot Controller
- 281 IRC5
- 48 OmniCore
- 3 RobotStudio AR Viewer
- 740 RAPID Programming
- 16 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
