Robot not reorienting around tcp, works in robotstudio but not on real robot.
                    SBENO
                    Hello, so I have a problem.
Have been trying to figure this on my own but now i think it s time to ask for help.
So I´ve created a tool in solidworks and made a .STEP file to get it into Robotstudio.
Everything has been working fine, up until I downloaded it into the real controller for verification.
Then i noticed that the robot is not rotating correctly around the TCP.
Video:https://imgur.com/a/KaEbRiv
Do you have any ideas?
I´ve verified that the tool is mounted correctly on the robot, that the revolution counters are updated and also that the X,Y,Z coordinates are correct.
Updated to RW 6.15.06.00.
The robot has been in our development site since 2017 with no service that i know of(If this is information that could be helpful)
Thanks in advance!
Best regards, ENO
Thanks in advance!
Best regards, ENO
            There should be a sticker on the robot arm which has the robot type, serial numbers and those numbers for calibration offsets. These numbers should match what you see in the pendant. AT this point, please also check that the robot serial numbers matches the sticker on the controller.Lee Justice0
            Did you verify the calibration offsets also?
 Teach the TCP and see if you can get a good result.Lee Justice0
 Have a look here: https://imgur.com/a/vfNqVuolemster68 said:Did you verify the calibration offsets also?
 Max error 5.12mm.
 We do not have a tcp pen, we are using the welding wire from the nozzle.
 The robot is an IRB4600-40/2.55C, as I´ve understood this is not the most accurate robot but i feel like we should get a better value than that anyway.0
            Are you telling me that is the result of teaching a tcp? And what about the calibration offsets?Lee Justice0
 Please have a look on this, is this what you are searching?lemster68 said:Are you telling me that is the result of teaching a tcp? And what about the calibration offsets?
 https://imgur.com/a/uiMMS3O
 They no not match, so i guess this might be my problem.0
            Hello,You can check your motor turn with MoveAbsJ [0,0,0,0,0,0],...☑️2024 - RobotStudio® User Group0
- 363 IRC5
- 80 OmniCore
- 853 RAPID Programming
- 31 AppStudio
