Revolution counters not updated
Hi all,
I have been working with IRB 14000 YuMi and recently I have been getting the error 'Revolution counters not updated' from the FlexPendant. The problem is that when I call the calibration routine, the joints can be calibrated just fine, and the 'Calibration' section also shows both arms calibrated. However, once I power off the robot and restart, 'Revolution counters not updated' shows up again.
One thing that I found might be related to the problem is that Axis Calibration seems to be not properly stored in memory. As shown in the image:
However, after checking options on FlexPendant for days, I still haven't figure out how to have the Calibration results stored. Has anyone experienced this error before? Any help is appreciated! Thanks in advance.
Seems like the SMB battery is dead, replace it and your calibration values will not be lost on power down
Hi Xerim! Thanks a ton! That makes a lot of sense! I will go check if the SMB battery is dead.0
I have checked the battery and the voltmeter reads only 180mv. Yeah the battery should be dead for good. Does anyone happen to know where can we buy these SMB batteries? I found some suppliers on eBay but they don't seem to be very reliable... Many thanks.HainingLuo said:Hi Xerim! Thanks a ton! That makes a lot of sense! I will go check if the SMB battery is dead.0 -
I found this battery from the Product manual, spare parts - IRB 14000, but I would call ABB to double check. The spare part number may be out of date.0
Sorry for my late reply and thanks again, Xerim! The battery number is exactly what I found on yumi! I will check the spared parts! Thanks again!xerim said:I found this battery from the Product manual, spare parts - IRB 14000, but I would call ABB to double check. The spare part number may be out of date.0 -
We have a YUMI 14000 in school, and i need to change the batteries. But i cant find any guide how to do it? should i turn the power OFF or do it while power is ON? I found a video that says it should be OFF, but the robot type in the video is different. Here is the link of video.
https://youtu.be/eRBxpsIxQWg?si=1c-HebasTAWL1FfF
Can someone give any advice? i will appreciate it.0 -
Please see attached from the product manual.
The power should be off as you have to remove the cover of the robot exposing electrical circuits.0
- 363 IRC5
- 81 OmniCore
- 853 RAPID Programming
- 32 AppStudio
