FlexPendant Problems caused by RW
I'm using RS5.07.01.
And I made a test:I creat 4  virtual system (which only contain a IRB6600)based on 4 RobWare: 5.07.5002/5.07.4002/5.07.0153/5.07.1023
The result is only in the systems based on 0153 and 1023 I could open FlexPendant. While based on 4002 and 5002, it pops up an error window.
Can you tell me why?image
  • It sounds like its not forward compatible with newer versions of RW, i.e. 5.07.04/05. You would probably need a newer version of RS.
    Russell Drown
  • Yes, I agree with you. So I update RS to 5.08.01
    Still I build a new system with a naked IRB 6600.
    When I open virtual flexpendant, an error window pops up and I cannot find "program editor" in the flexpendant.
    Why~image
