Issue with Profinet configuration
Luxrobotic
in IRC5
Hi I'm currently trying to configure the Profinet communication on IRC5 RW 5.15 robots.
We have the option 888-1 PROFINET IO m/s (DSQC678 board).
How should the board be connected to the LAN port ?
We have first tried with a connection between the board and the Siemens PLC.
Then we could see is in the TIA portal, but we can't communicate.
If we connect to the LAN port, we don't se it anymore in the TIA portal.
Could it also be a question of GSDML file ?
We use GSDML-V2.2-Siemens-CP16xx-20100709
Thanks for your help.
Regards
http://www.luxrobotic.com
Cornet Raymond
Manager
+352 621 354 570
raymond.cornet@luxrobotic.com
HP ZBook Fury 16 G11
Do you need the manual for that?Lee Justice0
Hi,I have Application manual PROFINET master/slaveBut it doesn't help me a lotRegardsCornet RaymondManager+352 621 354 570raymond.cornet@luxrobotic.com
http://www.luxrobotic.comHP ZBook Fury 16 G110 -
What specific version of RW 5.15 does the robot have and what is the main computer in the controller?Lee Justice0
Hello,There is 14 robots in the installation with different RobotWare Versions : 5.15.9149.15 and 5.16.0005.00.I can't give you the main computer type.finally I received some information from an ABB engineer.The DSQC678 board can only be configure with a specific software PROFINET configurator which run under XP, with a dongle.It's no longer supported either available.The solution should be to install the option 840-3 ProfiNet fieldbus Adapter with a DSQC688 board.Would you have an alternative solution ?
- 304 PowerPacs
- 356 IRC5
- 850 RAPID Programming
- 26 AppStudio
