Issue with Profinet configuration
2»
  • Regards
    Cornet Raymond
    Manager
    +352 621 354 570
    raymond.cornet@luxrobotic.com
    http://www.luxrobotic.com
    HP ZBook Fury 16 G11
  • Luxrobotic
    Luxrobotic ✭✭
    edited October 10
    There is 2 robots connected to PLC
    Regards
    Cornet Raymond
    Manager
    +352 621 354 570
  • There is 2 robots connected to PLC
    Regards
    Cornet Raymond
    Manager
    +352 621 354 570
  • Luxrobotic
    Luxrobotic ✭✭
    edited October 10
    Regards
    Cornet Raymond
    Manager
    +352 621 354 570
  • lemster68
    lemster68 ✭✭✭
    OK.  So, the profinet gateway address from the last configuration is the IP address of this switch?
    Lee Justice
  • Hello,
    sorry for the late reply.
    The Ip address of the DSQC-678 board is 192.168.10.51
    Regards
    Cornet Raymond
    Manager
    +352 621 354 570
  • lemster68
    lemster68 ✭✭✭
    Hello again.  Have you added the EIO_UNIT for the IO, PN_INTERNAL_SLAVE Unit Type?  And the switch IP address matches the gateway IP address?
    Lee Justice
  • We are not able to change the current IP address which is 192.168.1.100.
    As I understood we could only make by generating a xdb file with the PLC software, that we didn't succed until now.
    Regards
    Cornet Raymond
    Manager
    +352 621 354 570
  • lemster68
    lemster68 ✭✭✭
    There may be a misunderstanding here.  I am not asking you to change the switch IP address, just make the gateway in the EIO.cfg match the switch address.
    Lee Justice
  • If I set the IP address in the cfg file, the PLC doesn’t see the change. This should be linked to the xdb file where the address is still  192.168.1.100.
    Regards
    Cornet Raymond
    Manager
    +352 621 354 570
  • lemster68
    lemster68 ✭✭✭
    Have you created the EIO_UNIT in your EIO?
    Lee Justice
  • The robot is a used one,  the config was in the controller
    Regards
    Cornet Raymond
    Manager
    +352 621 354 570
  • lemster68
    lemster68 ✭✭✭
    Last thing to ask:  Have you managed to name the station in profinet using some kind of profinet configuration tool?
    Lee Justice
  • That's the problem we have, we did a lot of tests, without success. Only one time, but just for a few minutes.
    We can't make any change on IP address or name
    Regards
    Cornet Raymond
    Manager
    +352 621 354 570
