sync to VC in RS window
hi i f i create a module i AWPP and sync to wc there is no promlem.
But if i sync to vc from RS interface i dont get the weldsequence createt from AWPP in the module, why is that.
The reason is that i what "*"(asterix) instead of robtargets in my module.
I will then have to sync from RSaInterface, make all tagets "true" and then sync. then delete the module in RSonline,and then sync again to VC from the AWPP interfaceto get my weldsequence in the module.
Kent Zibrandtsen
Dept manager robot welding
Kez@hardi-international.com
Hi, Next release of AWPP will have the function to sync inline targets. As it is today your way of working is correct except you can use programming tab in RS instead of starting RSonline.0
- 5.4K RobotStudio
- 382 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 247 ScreenMaker
- 2.7K Robot Controller
- 281 IRC5
- 48 OmniCore
- 3 RobotStudio AR Viewer
- 739 RAPID Programming
- 16 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
