Can't warmstart controler in Online
Klaus
I get thet exeption when trying the online controller. I can edit rapid and change configuration but not restart.
RobotStudio .NET exception: Unknown Error: Warmstart
Base exception: COMException
Exception from HRESULT: 0x800404A5
at Interop.LgRobServices.LgRobControllerClass.Restart(LgRobCmdParam& pRobParam, LgRobRestartMode restartMode)
at ABBInternal.OnlineManagement.CommandHandlers.btn_ExecuteCommand(Object sender, ExecuteCommandEventArgs e)
at ABB.Robotics.RobotStudio.Environment.CommandBarButton.RaiseExecuteCommand()
Best Regards Klaus
Best Regards
Klaus Soenderhegn
www.cadalysator.dk
Klaus Soenderhegn
www.cadalysator.dk
Hi Klaus,From the error code, it seems that RS is in some undefined state.* Does the problem occur for RC or VC (RC I assume)?* Does the problem disappear after you delete and re-add the controller?* Does the problem disappear after you restart RS?* Can you reproduce the problem (after having worked around it)? If so, what are the steps?Henrik Berlin
ABB0
- 5.4K RobotStudio
- 381 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 247 ScreenMaker
- 2.7K Robot Controller
- 281 IRC5
- 47 OmniCore
- 3 RobotStudio AR Viewer
- 739 RAPID Programming
- 16 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
