Where to get Help
Where can I get help with RS 5.11 I have installed/de-installed 2 times and it runs fine once and then locks as per the screen dump and the attached report.
webwiz/2637/RS_5.11_Error.JPG
HiHave you installed the 5.11 baseware first ?Have you done a restart of your pc ?What do you mean by "runs fine once and then locks ".Regards
Knud Erik Lindberg
Jorgensen Engineering0 -
Hi, yes I have gone through the install in the correct way, the error I get is an unhandled exception error. However, I can run RS after install only once, open stations, create stations ETC. Once I shut down my PC I get this error. I have tried uninstalling and re-installing without success. I get the same error. I have attached a dump of the error log.0
Follow the instruction on the following page to get help:http://forums.robotstudio.com/forum_posts.asp?TID=2164
Henrik Berlin2008-10-13 11:44:45Alternatively, you can upload the support log (the most interesting part is usually the latest "Fault Log File") to this thread.Henrik Berlin
Hi HenrikFor some reason the fault log wouldn't upload previously. Please find it attached. My contact information is Dave Young ABB Milton Keynes 00447885333713 (Mobile) or 00441908350300 (Office)Hope this helpsDave
It's good to see that the forum works well! I'll look elsewhere for a solution. Thanks for your attention.
- 348 IRC5
- 846 RAPID Programming
- 21 AppStudio
