DeviceNames/Download to hdd # RESOLVED [WebWare SDK]
Hi again!
In the manual I did not find a list of valid device-names. Could someone help? What devicenames mean what on IRC5/S4C/S4C+??
also, how do I specify the target of an operation to the local disc?
(I mean f.e. backup a file from S4C+ to local hdd). Do I need NFS/FTP? Can I also do it via S4 commands?
I got a lot of questions, I know. I hope someone could help.
Maybe some code-fragments will help to understand how to do this kind of stuff.
If all is done, i will post an new Topic with all the needed code-fragments.
thx in advance
mathric38404,321423611101000111
            Hello, There is a list of File system references in the WebWare SDK Help. Please check: Contents tab -> WebWare ActiveX Control Library -> ActiveX Controls ->Helper Control -> Robot Controller File System Reference. Methods such as S4Backup will perform a robot backup to the robot memory device only. If you want to transfer files from robot <-> PC, you should use the Helper methods such as S4FileCopy or use the File Manager control ______________________________
 Anders Dannberg
 ABB Automation Technologies
 Support Engineer0
            It Still does not work. I did the following .... '**************************************************
 ' author: Mathias Richter
 ' date: 2005-02-16
 ' function: lists all available Interlink ALIASes
 ' in debug-window
 Dim i_Counter As Integer
 Dim i_ErrorCodeABB As Integer
 Debug.Print "Displaying all Alias in INTERLINK (" & ABBHelper.AliasListCount & ")"
 For i_Counter = 0 To ABBHelper.AliasListCount - 1
 Debug.Print "Alias[" & i_Counter & "]" & ABBHelper.AliasList(i_Counter)
 Next i_Counter
 ' date: 2005-02-16
 ' function: connect to a ALIAS (ABB-Robot)
 ' checks Interlink for valid ALIAS
 ' returns connectionstate in debug-window
 ' in: index
 ' remarks: index directly addresses the ALIAS
 ' see: ListAllAlias
 ' check aliasIndex <=?=> aliasName wanted
 Debug.Print "connecting to ALIAS(0)"
 If 0 > ABBHelper.AliasListCount - 1 Then
 MsgBox "Alias nicht in Liste!"
 End If
 ABBHelper.Robot = ABBHelper.AliasList(0)
 Select Case ABBHelper.InterfaceState
 Case ABB_Connected: Debug.Print "Connection established"
 Case ABB_Disconnected: Debug.Print "Connection failed: disconnected"
 Case ABB_Halted: Debug.Print "Connection halted by Interlink"
 Case ABB_NoAliasInList: Debug.Print "Alias not found"
 Case ABB_Simulated: Debug.Print "Connection simulated"
 End Select
 ' date: 2005-02-16
 ' function: test
 Debug.Print "Testing environment"
 Dim i_ResultSpec As Integer
 Dim i_DirMode As Integer
 Dim l_ResultID As Long
 i_ResultSpec = 3
 i_DirMode = 0 'nicht implementiert und somit 0
 l_ResultID = 0
 GetDevicesPresentABB
 'Alle Ordner im Hauptordner anzeigen
 Debug.Print ABBHelper.ErrorMessage(ABBHelper.S4Dir(ABBHelper.DevList(0), s_Path, i_DirMode, i_ResultSpec, l_ResultID))
 Debug.Print "listing all directorys:"
 For i_Counter = 0 To ABBHelper.DirListCount - 1
 Debug.Print "Dir(" & i_Counter & "):'" & ABBHelper.DirList(i_Counter) & "'"
 Next i_Counter
 'Alle Dateien im Hauptordner anzeigen
 Debug.Print "listing all files"
 For i_Counter = 0 To ABBHelper.FileListCount - 1
 Debug.Print "File(" & i_Counter & "):'" & ABBHelper.FileList(i_Counter) & "'"
 Next i_Counter
 Debug.Print ABBHelper.S4FileCopy(ABBHelper.DevList(0), ABBHelper.FileList(0), App.Path & "BackupABB", ABBHelper.FileList(0), 0, l_ResultID)
 Debug.Print ABBHelper.ErrorMessage(ABBHelper.S4FileCopy(ABBHelper.DevList(0), ABBHelper.FileList(0), App.Path & "BackupABB", ABBHelper.FileList(0), 0, l_ResultID))
 Debug.Print ABBHelper.ErrorMessage(ABBHelper.S4Dump(App.Path & "BackupABB.Dump", 0, l_ResultID))
 Debug.Print "done testing"
 ' date: 2005-02-16
 ' function: disconnect from ALIAS (ABB-Robot)
 Debug.Print "disconnecting from ALIAS('" & ABBHelper.Robot & "')"
 If (ABBHelper.InterfaceState = ABB_Disconnected) Or _
 (ABBHelper.InterfaceState = ABB_NoAliasInList) Then
 MsgBox "Error: no connection"
 End If
 ABBHelper.Robot = ""
 Case ABB_Connected: Debug.Print "Connection stil alive"
 Case ABB_Disconnected: Debug.Print "Connection disconnected"
 Case ABB_NoAliasInList: Debug.Print "Connection terminated"
 Case ABB_Simulated: Debug.Print "Connection stil simulated"
 End Select
 'ABBHelper.
 Endthe routine getdevices ... Public Sub GetDevicesPresentABB()
 ' date: 2005-02-16
 ' function: get the devicenames from the robot-
 ' controller
 ' remarks: displays devicenames in direct-window
 frmTest.ABBHelper.S4GetFileDevInfo 0, l_ResultID
 Debug.Print "Displaying devices present (" & frmTest.ABBHelper.DevListCount & ")"
 For i_Counter = 0 To frmTest.ABBHelper.DevListCount - 1
 Debug.Print "Dev(" & i_Counter & "):'" & frmTest.ABBHelper.DevList(i_Counter) & "'"
 Next i_Counter
 End Submy output is: Displaying all Alias in INTERLINK (3)
 Alias[0]S4VIRTCRTL
 Alias[1]S4VIRTCTRL
 Alias[2]ROBOT
 Testing environment
 Displaying devices present (1)
 Dev(0):'ram1disk:'
 Unknown Error
 Dir(0):'..'
 Dir(1):'BACKUP'
 Dir(2):'home'
 Dir(3):'syspar'
 Dir(4):'SYSTEM'
 listing all files
 File(0):'AAAH.prg'
 File(1):'base_mt.sys'
 File(2):'ctrl.bin'
 File(3):'image.bin'
 File(4):'katakan.tpu'
 File(5):'key.id'
 File(6):'keystr.txt'
 File(7):'mode.sav'
 File(8):'opt_l0.cmd'
 File(9):'pgmcpl1.log'
 File(10):'program.id'
 File(11):'ROBOT~1.ROB'
 File(12):'startup.cmd'
 File(13):'SYSPAR.LOG'
 File(14):'SYSTEM~1'
 File(15):'user.sys'
 Unknown Error
 Unknown Error
 done testing
 disconnecting from ALIAS('S4VIRTCRTL')
 Connection terminatedAll S4Filecopy and S4Dump return the code 0, but when I look into the directory it is still empty what did I wrong? --------
 010001110
            Are you communicating with a real robot or a Virtual Controller?
 You are trying to save the backup generated by S4Dump on a local PC, which is not a supported behaviour. You can use the S4Dump & S4Backup methods on the the robots memory device only.
 For instance, try the following:
 Dim intTest As Integer
 Dim lngResult As Long
 intTest = AxHelper1.S4Dump("robotdir", 3, lngResult)
 =======================================Also, as long as you are using the value 0 as a ResultSpec, you will not recieve proper error messages (see my previous post on ResultSpec codes).
 Are you sure that the path is correct when copying the file?
 Anders Dannberg
 Support Engineer0
            Okay i found the error: devicename is "ram1disk:" app.path is "c:abbackup" both have to be ended by "" so i modyfied like this: Debug.Print ABBHelper.S4FileCopy(ABBHelper.DevList(0) & "", ABBHelper.FileList(0), App.Path & "", ABBHelper.FileList(0), 3, l_ResultID)
 both works fine. -------- --------
 010001110
- 363 IRC5
- 80 OmniCore
- 853 RAPID Programming
- 31 AppStudio
