DeviceNames/Download to hdd # RESOLVED [WebWare SDK]
Hi again!
In the manual I did not find a list of valid device-names. Could someone help? What devicenames mean what on IRC5/S4C/S4C+??
also, how do I specify the target of an operation to the local disc?
(I mean f.e. backup a file from S4C+ to local hdd). Do I need NFS/FTP? Can I also do it via S4 commands?
I got a lot of questions, I know. I hope someone could help.
Maybe some code-fragments will help to understand how to do this kind of stuff.
If all is done, i will post an new Topic with all the needed code-fragments.
thx in advance
mathric38404,321423611101000111
There is a list of File system references in the WebWare SDK Help.
Please check: Contents tab -> WebWare ActiveX Control Library -> ActiveX Controls ->Helper Control -> Robot Controller File System Reference.
Methods such as S4Backup will perform a robot backup to the robot memory device only. If you want to transfer files from robot <-> PC, you should use the Helper methods such as S4FileCopy or use the File Manager control
______________________________
Anders Dannberg
ABB Automation Technologies
Support Engineer0 -
It Still does not work.
I did the following ....
' author: Mathias Richter
' date: 2005-02-16
' function: lists all available Interlink ALIASes
' in debug-window
Dim i_Counter As Integer
Dim i_ErrorCodeABB As Integer
Debug.Print "Displaying all Alias in INTERLINK (" & ABBHelper.AliasListCount & ")"
For i_Counter = 0 To ABBHelper.AliasListCount - 1
Debug.Print "Alias[" & i_Counter & "]" & ABBHelper.AliasList(i_Counter)
Next i_Counter
' date: 2005-02-16
' function: connect to a ALIAS (ABB-Robot)
' checks Interlink for valid ALIAS
' returns connectionstate in debug-window
' in: index
' remarks: index directly addresses the ALIAS
' see: ListAllAlias
' check aliasIndex <=?=> aliasName wanted
Debug.Print "connecting to ALIAS(0)"
If 0 > ABBHelper.AliasListCount - 1 Then
MsgBox "Alias nicht in Liste!"
End If
ABBHelper.Robot = ABBHelper.AliasList(0)
Select Case ABBHelper.InterfaceState
Case ABB_Connected: Debug.Print "Connection established"
Case ABB_Disconnected: Debug.Print "Connection failed: disconnected"
Case ABB_Halted: Debug.Print "Connection halted by Interlink"
Case ABB_NoAliasInList: Debug.Print "Alias not found"
Case ABB_Simulated: Debug.Print "Connection simulated"
End Select
' date: 2005-02-16
' function: test
Debug.Print "Testing environment"
Dim i_ResultSpec As Integer
Dim i_DirMode As Integer
Dim l_ResultID As Long
i_ResultSpec = 3
i_DirMode = 0 'nicht implementiert und somit 0
l_ResultID = 0
GetDevicesPresentABB
'Alle Ordner im Hauptordner anzeigen
Debug.Print ABBHelper.ErrorMessage(ABBHelper.S4Dir(ABBHelper.DevList(0), s_Path, i_DirMode, i_ResultSpec, l_ResultID))
Debug.Print "listing all directorys:"
For i_Counter = 0 To ABBHelper.DirListCount - 1
Debug.Print "Dir(" & i_Counter & "):'" & ABBHelper.DirList(i_Counter) & "'"
Next i_Counter
'Alle Dateien im Hauptordner anzeigen
Debug.Print "listing all files"
For i_Counter = 0 To ABBHelper.FileListCount - 1
Debug.Print "File(" & i_Counter & "):'" & ABBHelper.FileList(i_Counter) & "'"
Next i_Counter
Debug.Print ABBHelper.S4FileCopy(ABBHelper.DevList(0), ABBHelper.FileList(0), App.Path & "BackupABB", ABBHelper.FileList(0), 0, l_ResultID)
Debug.Print ABBHelper.ErrorMessage(ABBHelper.S4FileCopy(ABBHelper.DevList(0), ABBHelper.FileList(0), App.Path & "BackupABB", ABBHelper.FileList(0), 0, l_ResultID))
Debug.Print ABBHelper.ErrorMessage(ABBHelper.S4Dump(App.Path & "BackupABB.Dump", 0, l_ResultID))
Debug.Print "done testing"
' date: 2005-02-16
' function: disconnect from ALIAS (ABB-Robot)
Debug.Print "disconnecting from ALIAS('" & ABBHelper.Robot & "')"
If (ABBHelper.InterfaceState = ABB_Disconnected) Or _
(ABBHelper.InterfaceState = ABB_NoAliasInList) Then
MsgBox "Error: no connection"
End If
ABBHelper.Robot = ""
Case ABB_Connected: Debug.Print "Connection stil alive"
Case ABB_Disconnected: Debug.Print "Connection disconnected"
Case ABB_NoAliasInList: Debug.Print "Connection terminated"
Case ABB_Simulated: Debug.Print "Connection stil simulated"
End Select
'ABBHelper.
Endthe routine getdevices ...
Public Sub GetDevicesPresentABB()
' date: 2005-02-16
' function: get the devicenames from the robot-
' controller
' remarks: displays devicenames in direct-window
frmTest.ABBHelper.S4GetFileDevInfo 0, l_ResultID
Debug.Print "Displaying devices present (" & frmTest.ABBHelper.DevListCount & ")"
For i_Counter = 0 To frmTest.ABBHelper.DevListCount - 1
Debug.Print "Dev(" & i_Counter & "):'" & frmTest.ABBHelper.DevList(i_Counter) & "'"
Next i_Counter
End Submy output is:
Displaying all Alias in INTERLINK (3)
Alias[0]S4VIRTCRTL
Alias[1]S4VIRTCTRL
Alias[2]ROBOT
Testing environment
Displaying devices present (1)
Dev(0):'ram1disk:'
Unknown Error
Dir(0):'..'
Dir(1):'BACKUP'
Dir(2):'home'
Dir(3):'syspar'
Dir(4):'SYSTEM'
listing all files
File(0):'AAAH.prg'
File(1):'base_mt.sys'
File(2):'ctrl.bin'
File(3):'image.bin'
File(4):'katakan.tpu'
File(5):'key.id'
File(6):'keystr.txt'
File(7):'mode.sav'
File(8):'opt_l0.cmd'
File(9):'pgmcpl1.log'
File(10):'program.id'
File(11):'ROBOT~1.ROB'
File(12):'startup.cmd'
File(13):'SYSPAR.LOG'
File(14):'SYSTEM~1'
File(15):'user.sys'
Unknown Error
Unknown Error
done testing
disconnecting from ALIAS('S4VIRTCRTL')
Connection terminatedAll S4Filecopy and S4Dump return the code 0, but when I look into the directory it is still empty
what did I wrong?
010001110 -
Are you communicating with a real robot or a Virtual Controller?
You are trying to save the backup generated by S4Dump on a local PC, which is not a supported behaviour. You can use the S4Dump & S4Backup methods on the the robots memory device only.
For instance, try the following:
Dim intTest As Integer
Dim lngResult As Long
intTest = AxHelper1.S4Dump("robotdir", 3, lngResult)
=======================================Also, as long as you are using the value 0 as a ResultSpec, you will not recieve proper error messages (see my previous post on ResultSpec codes).
Are you sure that the path is correct when copying the file?
Anders Dannberg
Support Engineer0 -
Okay i found the error:
devicename is "ram1disk:"
app.path is "c:abbackup"
both have to be ended by "" so i modyfied like this:
Debug.Print ABBHelper.S4FileCopy(ABBHelper.DevList(0) & "", ABBHelper.FileList(0), App.Path & "", ABBHelper.FileList(0), 3, l_ResultID)
both works fine.--------
010001110
- 5.4K RobotStudio
- 384 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 247 ScreenMaker
- 2.7K Robot Controller
- 279 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 736 RAPID Programming
- 15 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
