Import of geometries. Errors.
jesus
Hello.
I have problems with the import of geometries. The files are kind STEP or ACIS.
RS is not able to import files larger than 40MB.
Until that limits the volume of file RS is capable of importing without giving bug?.
Thank you very much.
Jesus.
Hi Jesus.I have imported satfiles of 500 mb. It takes time to import but it works.After import i save them as lib. Delete them and import the lib and it works very wellBR KlausBest Regards
Klaus Soenderhegn
www.cadalysator.dk0 -
Hi,The function "Enable Healing" can cause some geometries to grow unexpectedly. Try to uncheck it and import the geometry again. The function is enabled/disabled by the checkbox in the "Import Geometry" dialog, see below.Henrik Berlin
ABB0
- 337 IRC5
- 67 OmniCore
- 831 RAPID Programming
- 14 AppStudio
