RS31 does not start !!
I am using ThinkPad T40p with 1GB of RAM. Everyday, I have to start RS and close at least three times before RS is running properly. I reinstalled RS, but the problem reamins. Is anybody know the cause? Also, I encountered the RS is not running when using Track.
CPU; 1.6GHz RAM; 1GB OS; Windows XP SP1
Mitz
Hello Mitz,
How do you mean start and close? Does RobotStudio crash? How does the errormessage look?
Best regards
/Ulrika Mor?n
I mean RS freeze at least a few times, before it is running properly. No error message in the RS, because it crshes.
Mitz
Hello again Mitz,
I see you are a member of the pickmaster forum, have you got a lot of ABB softwares installed?
Just to make sure; it's when you are starting RobotStudio, not when starting the virtual controller that you get the problem?
Best regards
/Ulrika Mor?n
