Motion Error Detection
If a motion error occurs in one arm of the YuMi robot, the motion error is displayed on the Pendant stating which arm caused the motion error. But this discernment between arms is not available in RAPID, only that a motion error occurred. As a workaround, it's possible work out which arm caused the motion error by trapping the motion error in both arms and comparing the time difference between when the trap routines were called because the arm that caused the motion error will call its trap routine before the other arm.
MODULE LeftArm PROC main() ! Initialise the Motion Error Detector. MED_Initialise TASK_LEFT_ARM,TASK_RIGHT_ARM; ! ! Loop through some movements. ! WHILE bRun DO ENDWHILE MED_Done; ERROR TPWriteProc "main.ERROR","@"\n:=ClkRead(clock1\HighRes); ENDPROC ENDMODULE<br>
MODULE RightArm PROC main() ! Initialise the Motion Error Detector, but swap the tasks relative to the other arm. MED_Initialise TASK_RIGHT_ARM,TASK_LEFT_ARM; ! ! Loop through some movements. ! WHILE bRun DO ENDWHILE MED_Done; ERROR TPWriteProc "main.ERROR","@"\n:=ClkRead(clock1\HighRes); ENDPROC ENDMODULE<br>
Place a copy of the following modules in each arm.
MODULE MotionErrorDetector
RECORD MotionErrorData
num seconds;
bool error_detected;
ENDRECORD
PERS MotionErrorData MED_Data{2};
LOCAL VAR TaskID this_arm;
LOCAL VAR TaskID other_arm;
LOCAL VAR clock clk;
LOCAL VAR intnum interrupt;
VAR bool MED_motion_error:=FALSE;
TRAP MED_Trap
MED_Data{this_arm}.seconds:=ClkRead(clk\HighRes);
TPWriteProc "MED_Trap","BEGIN @"\n:=MED_Data{this_arm}.seconds;
! Ensure the time is read in both arms before comparing the time difference.
SyncTasksPP this_arm,other_arm;
! Set a flag to indicate that this arm has a motion error.
! This IF statement depends upon our arm interrupt being called before the other arm interrupt.
IF MED_Data{this_arm}.seconds<MED_Data{other_arm}.seconds THEN
MED_Data{this_arm}.error_detected:=TRUE;
MED_Data{other_arm}.error_detected:=FALSE;
TPWriteProc "MED_Trap","TaskID="+NumToStr(this_arm,0);
ENDIF
! Set a flag to indicate that a motion error occurred.
MED_motion_error:=TRUE;
TPWriteProc "MED_Trap","END";
ERROR
TPWriteProc "MED_Trap.ERROR","@"\n:=ClkRead(clock1\HighRes);
ENDTRAP
PROC MED_Initialise(TaskID this,TaskID other)
this_arm:=this;
other_arm:=other;
MED_ResetSyncStartClock;
! Delete any previous assignemnt before assigning it.
IDelete interrupt;
CONNECT interrupt WITH MED_Trap;
IError MOTION_ERR,TYPE_ERR,interrupt;
PROC MED_ResetSyncStartClock()
ClkReset clk;
ClkStart clk;
PROC MED_Done()
IDelete interrupt;
ENDMODULE<br>MODULE Synchronisation
ALIAS bool SyncStep;
ALIAS num TaskID;
RECORD R_Sync
SyncStep SyncStep1;
SyncStep SyncStep2;
ENDRECORD
CONST TaskID TASK_LEFT_ARM:=1;
CONST TaskID TASK_RIGHT_ARM:=2;
PERS R_SyncPP SyncPP{2};
PROC SyncTasksPP(TaskID task_id_this,TaskID task_id_other)
! Reset the flag to say we are not at sync step 2.
SyncPP{task_id_this}.SyncStep2:=FALSE;
! Set the flag to say we are at sync step 1.
SyncPP{task_id_this}.SyncStep1:=TRUE;
! Wait for other task to reach step 1.
WaitUntil SyncPP{task_id_other}.SyncStep1;
! Set the flag to say we are at step 2.
SyncPP{task_id_this}.SyncStep2:=TRUE;
! Wait until the other task has computed our step 1 flag before continuing.
WaitUntil SyncPP{task_id_other}.SyncStep2;
! Reset this step 1 flag after step 2 to avoid a race condition.
SyncPP{task_id_this}.SyncStep1:=FALSE;
ERROR
TPWriteProc "SyncTasksPP.ERROR","";
ENDMODULE<br>MODULE Helper
PROC TPWriteProc(string sProcName,string s,\num n|bool b|pos p|orient o|dnum d)
VAR string str;
str:=sProcName+" "+s;
IF Present(n) THEN
TPWrite str\num:=n;
ELSEIF Present(b) THEN
TPWrite str\bool:=b;
ELSEIF Present(p) THEN
TPWrite str\pos:=p;
ELSEIF Present(o) THEN
TPWrite str\orient:=o;
ELSEIF Present(d) THEN
TPWrite str\dnum:=d;
ELSE
TPWrite str;
ENDIF
ERROR
TPWrite "TPWriteProc.ERROR @"\num:=ClkRead(clock1\HighRes);
ENDMODULE<br>Post edited by TimMathias on
