Read all joints
How can I read all the seven joints of YUMI?
Any suggestion will be appreciated!!!
  • You can calculate and store the joint values with CJointT() using RAPID code which reads the current angles of the arm axes and external axes.
    Example:
    VAR jointtarget joints;<br>joints := CJointT();<br>
  • Thanks a lot!
    It is working.
