Weird movement when doing a simple path
I have recorded a strange movement from the IRB 2600ID at a particular position. The funny thing is when jogging on the FlexPendant, I cannot observe that behavior.
Can anyone give me a hint?
Here is the video:
https://www.youtube.com/watch?v=CzINxJtnae0&feature=youtu.be&ab_channel=Tr%E1%BA%A7nAnh
Here is the video:
Configuration in your robtarget0
Agree this looks to be the configuration0
The robot ought to give an axis configuration error, why is it not?Lee Justice0
Has the config been turned off?0
That was my initial thought, but then it would just go to the position with the nearest configuration, not that strange 360 rotation.Lee Justice0
Is it a MoveJ for some crazy reason or MoveAbsJ?Lee Justice0
Hi lemster68,
I am using MoveJ. My reasoning for it is because our movement required both the TCP and the external axis to reach there at the same time. Do you think MoveL will solve this problem?0 -
vitsensei said:Hi lemster68,
I would start by looking at your robtarget for that specific target and confirm the configurations of it with reference to the other points that are correct.0 -
jmf and Graeme are right about the configuration. It does not matter if it is MoveJ or MoveL, (unless the robot is not controlling the external axis) all axes have to arrive at the programmed position at the same time.Lee Justice0
- 858 RAPID Programming
