Importing CAD fails - RS 6.03
I'm trying to import a .SLDASM archive (SolidWorks), and RS only takes few components from the whole thing. It's suppose that if I import the main SLDASM archive, the subordinate SLDASM and SLDPRT archives will appear on the RS but it doesn't.
Example:
Opening the main archive with eDrawings
Same archive with RS
No FAIL log, and for RS everything is OK.
Any idea? Need help please. Thanks
Un saludo, kind regards,
Daniel Aguilar
Automation Engineering
Have you tried using an interchange format like *.sat or *.step?
STEP files are not longer available for free in Robot Studio. I asked to engineering dept for a Sat file but they told me solidwork crashes when it tries to convert...graemepaulin said:Have you tried using an interchange format like *.sat or *.step?
Daniel Aguilar
Can engineering export each main component/machine to sat?
If Solidworks is crashing then there may be something in the file that is not quite right - hence RS not importing it correctly?
They are actually splitting the whole cad in different small archives, as solids, but I think this is not the way. I mean, I have the SolidWorks license for RS and I was able to open, even edit, complete solidworks with no problems, and now with the 6.03 I have many of them.graemepaulin said:Can engineering export each main component/machine to sat?
What I am not sure about, is if the software update matters.
Anyway, why the eDrawings can open the SolidWorks perfectly and the RS not?
Daniel Aguilar
You can try checking the "Convert CAD geometry to single part" box in the import dialog. That will cause the legacy CAD converter to be used.
Regards,
JohannesJohannes Weiman
Software Engineer
Hi,JWeiman said:Hi,
Regards,
Johannes
I've just tried it, with the same result. It only imports few parts of the whole cad group... I don't know what else do...
Daniel Aguilar
Another error importing a very simple Solid part.... Here is the log...RobotStudio .NET exception: Error 20 converting 'E:\Proyectos\Teneris Bay City\Robot\CAD 3D\HRM\Raqueta.SLDASM'Request: Operation failed.Advice: Contact customer support.Diagnostics: Operation failed with unspecified error.============================================Base exception: GeoExceptionError 20 converting 'E:\Proyectos\Teneris Bay City\Robot\CAD 3D\HRM\Raqueta.SLDASM'Request: Operation failed.Advice: Contact customer support.Diagnostics: Operation failed with unspecified error.en RobotStudio.Services.Geometry.ConverterService.OnError(SPAIopAcisError* error, String fileName, Boolean kasta)en RobotStudio.Services.Geometry.ConverterService.Import(String file, GraphicImportSettings settings, IProgressCallback progress)en RobotStudio.API.Internal.CadConverter.<>c__DisplayClass13_0.<ImportAsync>b__1()--- Fin del seguimiento de la pila de la ubicación anterior donde se produjo la excepción ---en System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)en System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)en RobotStudio.API.Internal.CadConverter.<ImportAsync>d__13.MoveNext()--- Fin del seguimiento de la pila de la ubicación anterior donde se produjo la excepción ---en System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)en System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)en RobotStudio.Services.GraphicConverters.GraphicConverterService.<ImportAsync>d__8.MoveNext()--- Fin del seguimiento de la pila de la ubicación anterior donde se produjo la excepción ---en System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)en System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)en System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task)en ABBInternal.StationLogic.ComponentServices.<ImportComponents>d__7.MoveNext()
Please, some help? Thanks.
Daniel Aguilar
Are you running 64-bit RobotStudio? Please note that SolidWorks 2015 and later is only supported in 64-bit, not 32-bit.
Regards,
Software Engineer
By the way, we are using SolidWorks 2016. What I don't understand is the official ABB Manual says it supports SolidWorks V18-ST7????JWeiman said:Are you running 64-bit RobotStudio? Please note that SolidWorks 2015 and later is only supported in 64-bit, not 32-bit.
Regards,
Johannes
Daniel Aguilar
That looks like a typo. RS 6.03 should support SolidWorks 2016.Johannes Weiman
Software Engineer
- 38 AppStudio
