Encoding Rapid Files
Can you please send it to me?
Thanks.
Pakpoom@robotsystem.co.th
Hello,can you send to me too?julienweb@free.frthank0
[QUOTE=jyrgen]
I have been using encode for many years without any problems. But now I got a new computer with Windows 7 I got a problem. When trying to execute encode i get the following message:<?: prefix = v ns = "urn:schemas-microsoft-com:vml" />
<?: prefix = o ns = "urn:schemas-microsoft-com:office:office" />
Anyone seen this? Is there a solution? Contacted ABB and they replied that they will no longer support the 12 year old software encode![/QUOTE]Running Win 7 64bit and the encode software is working great (no parameters in the encode was passed). Try to pass without the -s parameter and see if it works.Best regards
Alexander Källberg0 -
It's been uploaded to the forums, here's the link: http://forums.robotstudio.com/webwiz/1266/encode.zipAlexK2013-03-13 10:24:04Best regards
To encode some files you can put them for example to: 'D:\RobotStudio\RAPID Programs\CustomerA\Open\'
You can create a destination directory for example: 'D:\RobotStudio\RAPID Programs\CustomerA\Lock'
The attached ZIP-File has to be unzipped and the encode Directory has to be directly in 'C:\' So it will be: 'C:\encode'. I had trouble to execute the encode at an other place. I use Windows 7 with 64 bit.
To start the encoding you can use: 'EncodeCustomerA.bat' that will encode all *.sys files that are in the open directory.
The Syntax for the use of the encode instruction in: 'EncodeClosed.bat' could be like this: 'encode Open\Closed1402.sys Lock\Closed1402Enc.sys'
best regards
Marcel
2 -
Hi, can anyone know, where is the problem?
someone have functional version of encode module (win7 od win10) ?
Thank you very much in advance0 -
I tried more options, unfortunately just only copy encoded file.. without decode.0
Hi, the link http://forums.robotstudio.com/webwiz/1266/encode.zip no longer works. Can anyone create a new link?
JakubPost edited by mrva on0 -
I use my method. If you want to encode and decode modules (Files in your program. I won't do anything to the file system. Please remember clearly). You can contact me via email: procuba012@gmail.com
- 365 IRC5
