Robot to initial position
Vale
Hello to everybody!
I would like to move the robot to its initial position, I mean to the position at which the robot is when you buy it.
I know that the axis values are written on the robot arm and when I powered on for the first time the robot in calibration offset I checked to find exactly that values.
Does anybody knows how I can move again the robot to that position?
I tried to write a MoveAbsJ instruction, using as values the ones written on the robot arm, but in practice the position I find is different from the "original" one.
Thanks!
Thanks!
Hey -- I've done that before -- called it jShippingPos. You're right to think MoveAbsJ. Use the pendant's Jog menu, jog in joint, and see the joint values change as you jog.
The calibration offsets do not correspond to the joint angles. The best I can remember is that they are offset values from the resolver.Lee Justice0
PERS JointTarget jSyncPos:=[[0,0,0,0,0,0],[9E9,9E9,9E9,9E9,9E9,9E9]];
PROC MoveToSync()
MoveAbsJ jSyncPos,v100,fine,tool0;
Sorry, I misread the post. The same code applies but the joint angles will be different depending on the model. They can be found in the robot product manual, like so:
- 5.4K RobotStudio
- 384 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 405 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 279 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 734 RAPID Programming
- 15 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
