Frequently send position data to PLC
Paba
is it possible to send actual coordinates every ~0.5s to a PLC?
I tried so set up a new motion task for this but i guess this wont work..
Is there any kind of function or parameter that can monitor the coordinates?
best greetings
Works better when using CRobT with an actual reference to Motion Task
Is a cleaner solution possible?SetGO GO_y, Round((100*t_actTarget_R.trans.y)\Dec:=0);<code>SetGO GO_z, Round((100*t_actTarget_R.trans.z)\Dec:=0);t_actTarget_R:=CRobT(\TaskRef:=T_ROB_RID);<br>SetGO GO_x, Round((100*t_actTarget_R.trans.x)\Dec:=0);<br>
Post edited by Paba on0 -
I don't see anything wrong with that code.Lee Justice0
- 364 IRC5
- 81 OmniCore
- 853 RAPID Programming
- 32 AppStudio
