Storing a group output value to a variable
Hello All,
Am using IRB6700 robot for pick and place Palletization application. i recive the count values from siemens PLC using profinet. Assigned Group Input and Group Output to receive decimal values from PLC to robot. But i do nit know how to store the decimal values of Group Output in a variable.
Any sample code would be helpful. Or any other method also appreciated.
Best Answers
  • Thanks all.
    Also i would like to know is there any way to send and receive integer from PLC via Profinet instead of using Group inputs and outputs.
  • Set it up as an analog signal.  Refer to system parameter manual, inputs/outputs.
    Lee Justice
  • Prasanna
    Prasanna
    edited December 2019
    Hello all.
    I have got an error when executing the following Instruction:
    Var Signalgi PINFEED_CNT;
    var num count;
    count:=PINFEED_CNT;
    Am getting Alias IO instruction error.
  • The group input needs to be setup in the EIO configuration file not in RAPID.
    Are you using RobotStudio to do your programing or via the teach pendant?
