Event manager. Set DO to 1 when collision
Klaus
I have made an event that set a DO=1 when collision is detected. <?:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
The collistion_set is workin fine and i can simulate my DO in the I/O simulation window.
The event is made with following settings:
Activation = On
Trigger Type = Collision
Trigger Name = CollisionSet_2 (Works when running simulation
Trigger Parameter = Started
Action Type = Change I/O
Action System = System1 (Only System installed)
Action Name = DO_Soeg (Can be simulated in I/O window)
Action Parameter =1
Best Regards
Klaus Soenderhegn
www.cadalysator.dk
Klaus Soenderhegn
www.cadalysator.dk
Forgot to write that i use rs 5.07.1834.1023
Best Regards
Klaus Soenderhegn
www.cadalysator.dk0 -
Hi Klaus,
There is unfortunately a known problem with events trigged by collisions in RS 5.07.1834.1023. This problem will be solved in RobotStudio 5.08.
When does it releasedBest Regards
Klaus Soenderhegn
RS 5.08 will be released quarter one next year.Best regards,
ABB Robotics0
- 339 IRC5
- 67 OmniCore
- 832 RAPID Programming
- 14 AppStudio
